587,283 active members*
3,973 visitors online*
Results 1 to 3 of 3
Threaded View
    Feb 2016
    30
    The profile of my cut is not straight, help needed
    Hello,
    I have a problem with my plasma cutter, running on mach3 software. Everything is leveled and straight, it's ok when I cut 2-3mm steel, but when I go to 10mm, it rarely cuts it like it should, more often than not it's something like in the first picture. When cutting straight (like squares) it's ok, when cutting arcs and circles it makes this...angled profile? No idea even how to name it. I use Stanko plasma machine with 130A limit, I tried to cut it at 70 and square looks OK, circles do not. I ramped it up all the way to 120 and it produced similar results. I have 4 bars of air and I have no idea how to approach this problem. I do not have experience in this field, I'm setting it up for my friend. Thank you for all the help.
    This is the G-code I use for 66mm circle:
    ( circle_test 3/15/2016 3:36:09 PM )
    G21 G90 G64
    G0 Z-2.0
    ( move to the X,Y location of first toolpath )
    ( Profile1 )
    G0 X67.4195 Y53.8378
    G1 F500.0 Z5.0
    ( pierce height )
    G0 Z5
    ( torch on )
    M3
    G4 P1
    ( plunge to cuting depth )
    G1 Z5.0 F500.0
    G3 F400.0 X66.3032 Y49.7447 I1.4884 J-2.6047
    G2 X70.75 Y33.0 I-29.3032 J-16.7447
    G2 X20.125 Y3.7716 I-33.75 J0.0
    G2 Y62.2284 I16.875 J29.2284
    G2 X66.3032 Y49.7447 I16.875 J-29.2284
    G3 X70.3964 Y48.6284 I2.6047 J1.4884
    ( torch off )
    G4 P0.5
    M5
    ( small delay - s )
    G4 P0.5
    G0 Z-2
    M30
    Can't see anything wrong with it, or with the machine. I'm simply lost.
    Attached Thumbnails Attached Thumbnails IMG_20160308_134650.jpg   IMG_20160308_134630.jpg
  1. Replies: 12
    Last Post: 10-26-2020, 07:43 AM
  2. UCCNC profile needed for Gecko G540
    By curiosity22 in forum UCCNC Control Software
    Last Post: 08-20-2015, 10:32 AM
  3. Set me straight w/MC 5?
    By sirkossorg in forum Uncategorised CAM Discussion
    Last Post: 12-07-2012, 02:49 AM
  4. CNC Aluminium profile machine needed
    By [email protected] in forum Want To Buy...Need help!
    Last Post: 01-10-2011, 06:48 AM
  5. Joining Profile - Help needed
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 04-18-2005, 10:36 AM
