587,462 active members*
3,118 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Default K2-TC9 servos motor z axis braking options?
Results 1 to 2 of 2
    Mar 2015
    5
    I'm looking for a brake to add to my z axis motor to keep the head from dropping when the machine is powered off. I bought my motor from K2 cnc but I haven't been able to get on their site to contact them. After a little research, it appears that K2 CNC has gone out of business... I haven't been able to find a brake using the numbers on the motor. Does any one know of a braking system that will work for K2-TC9 servos motor? Is there another part number I should be searching for? I couldn't find any other numbers off the motor itself or the reciept... maybe even a spec print? Any insight on this would be a great help thanks!
    Jan 2014
    60
    Re: Default K2-TC9 servos motor z axis braking options?
    Alot of people use a spring or a gas strut
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  1. Replies: 1
    Last Post: 08-27-2015, 05:57 PM
  2. Location for default options?
    By Hood in forum BobCad-Cam
    Last Post: 03-05-2015, 08:06 PM
  3. Replies: 2
    Last Post: 01-30-2009, 06:35 PM
  4. dc motor braking
    By najnielkp in forum CNC Machine Related Electronics
    Last Post: 10-07-2005, 05:14 PM
