587,818 active members*
2,749 visitors online*
Results 1 to 3 of 3
    Apr 2010
    12
    How to calibrate table?
    When I cut straith lines on X or Y the cut is fine ( nice cut no jageth edges ) but when I cut curves and angels my cut is very jaget almost like a saw tooth.
    How do I correct this?
    Jan 2015
    12
    Re: How to calibrate table?
    Try reducing your speed on the curved cuts and see if the problem goes away. It could be whip in the axis movements.
    Apr 2014
    4
    Hi rat,
    Think it must be your drawings on dxf try a different resolution .
  1. Re-Calibrate After Every Reboot?
    By RPCElectronics in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2012, 11:12 PM
  2. Help me to calibrate my machine... please!
    By valletef in forum Mechanical Calculations/Engineering Design
    Last Post: 02-01-2012, 04:22 PM
  3. Need advise to calibrate...
    By valletef in forum Linear and Rotary Motion
    Last Post: 02-01-2012, 01:27 AM
  4. Will calibrate to 1 inch, but no where else
    By Bell 430 in forum Mach Software (ArtSoft software)
    Last Post: 02-15-2011, 03:33 PM
  5. calibrate tool eye
    By zed in forum Daewoo/Doosan
    Last Post: 09-25-2007, 04:17 PM
