587,303 active members*
3,851 visitors online*
Results 1 to 4 of 4
    Feb 2015
    2
    High voltage and water lines
    Hey all,
    I have built CNC machines before but this is my first laser build.
    The question I have is about safeties built into the laser power supply. I read where most/many laser power supplies have open circuit and over current protection. So will that save the system from a water line rupture where the coolant hits the connections? I'm an electrical engineer and there is just something about high voltage next to a water line that gives me nightmares.
    I've been reading about these systems for a long time and have never seen a conversation about what happens when a water line comes loose or ruptures.
    Anybody been there and done that?
    Jeff
    Feb 2009
    6028
    Re: High voltage and water lines
    Yes and yes, with 1000watt system no less. With di water, not a big deal, dry everything out and go. Now when the building water ruptured inside the cabinet, laser never worked again. Keep everything grounded and in a good cabinet.
    Jul 2013
    1
    Quote Originally Posted by underthetire View Post
    OK I appreciate the feedback. Yes I have learned to appreciate good grounding.
    Nov 2008
    643
    I'm using a PC coolant pump on my unit. With a 1.5gpm flow switch. Water pushes a plunger up which is a reed switch held by a spring. I had great flow from that pump but no pressure. I had to remove the spring to get the circuit to work. So these pumps just like inside of a PC don't have enough power to blow anything. If a line ruptured , the switch would kill the power to the tube.
  1. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
  2. High voltage & high power servo drive design
    By Xerxes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-23-2008, 03:24 AM
  3. Why such high voltage?
    By sp1nm0nkey in forum Stepper Motors / Drives
    Last Post: 12-31-2007, 07:52 AM
  4. Replies: 3
    Last Post: 03-21-2006, 03:00 AM
  5. PSU Voltage seems high.
    By mnewsholme in forum Hobbycnc (Products)
    Last Post: 04-26-2005, 09:26 AM
