To what pin do I connect the movable locating plate?
You can use input pins 10-13 and pin 15 on BoB. Goto pins and ports, look at input scroll down till you find "probe", check , install on any of those pins, select "auto-set" and be sure to save everything. Good luck with Big-Tex, I have been trying to figure out everything for a week and I'm just starting to get a handle on it.
OSD
Does the script for that button need to be altered or just change the settings in mach and it should work?
Sorry, I have two posts going and this one I will try tonight. I was referring to the laser on button for the cross hair question in my other thread.
Thanks for the quick repply.
This one is not working yet. Does pin 11 need to be tied high or low and if so how? Sorry for my ignorance.
read the M3 manual its all in there
for setting up the laser look here Tool Position Setting
http://danielscnc.webs.com/
being disabled is not a hindrance it gives you attitude
[SIGPIC][/SIGPIC]
What are we talking about?
