587,475 active members*
3,526 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > MC-80H NO LOW COOLANT ALARM
Results 1 to 4 of 4
    Jun 2007
    39
    Have a MC-80H with OSP 5000 that does not alarm out when coolant is low. The switch is good and it shows on the check data screen that it turns on and off. Possible parameter issue mabye ? I have all the books but I doen't see a parameter related to this.
    Apr 2009
    1262
    Re: MC-80H NO LOW COOLANT ALARM
    If I remember right, the parameter will only allow Alarm A or B, but you may not want either so that you don't stop part way through a drilling cycle. You may want to use VDIN to check the data input and then designate your own user alarm of level C to make it function the way you want.
    For example:
    IF [[VDIN[1158] AND 64]EQ 64]]NRUN (pick appropriate address in check data - see maintenance manual)
    VUACM[1]='COOLANT LOW'
    VDOUT[991]=1
    NRUN
    Best regards,
    Jun 2007
    39
    Well i was going to try this but I can not find the address I should be using I see all the variables like vmcod or vatol and all the other v addresses but where do find 1158 or 64. Perhaps a secret okuma handshake?
    Apr 2009
    1262
    Check the User Task section of your programming manual. It should reveal the check data address mapping.
  1. Coolant pump overtemp alarm
    By Joe Miranda in forum Cincinnati CNC
    Last Post: 07-17-2015, 03:06 PM
  2. Alarm 1032 coolant pump over load
    By Nastyzen in forum Colchester Tornado lathes
    Last Post: 05-01-2014, 03:06 PM
  3. Replies: 0
    Last Post: 12-26-2013, 04:26 PM
  4. Coolant Pump Overload Alarm
    By Spiderman in forum Tree
    Last Post: 05-03-2012, 07:28 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
