587,821 active members*
2,800 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > How to use multiple work sets with Geibbs ( G54 , G55 , G56)
Results 1 to 3 of 3
    Aug 2013
    3
    Hello all.
    I am very new to Gibbs's mostly learning from a co-worker and on my own. I want to be able to set up 2 vises in the mill with the same part in each vise such as G54 , G55. Can anyone explain to me how to get Gibb's to post this way ?
    Sep 2009
    135
    First check and see if you post can handle multiple work offsets. Go to preferences and turn on all post comments, next post a program. Look at the top of the code for information about WFO. It will tell you how to call a new WFO if it is available. You will call it by adding "NEWWFO55" in operation data in the At OP START comment for that operation. This WFO will stay active for successive operations until you change it or delete that operation.
    Another way is in the post dialog change the number of parts to 2 or more. This will post a program that calls different WFO's if you choose the Work Fixture radio button.
    Jan 2008
    73
    Re: How to use multiple work sets with Geibbs ( G54 , G55 , G56)
    Good multiple POST from JeffCNC.
  1. multiple work offsets
    By poster in forum Mastercam
    Last Post: 02-21-2013, 03:28 PM
  2. Work Off-sets are not being read.
    By leeputman in forum Haas Mills
    Last Post: 08-10-2012, 03:42 AM
  3. Probe sets work offsets
    By endmill in forum G-Code Programing
    Last Post: 01-17-2009, 06:28 PM
  4. Saving Work and Tool off-sets to floppy for later loading ?
    By iMisspell in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-29-2006, 05:09 AM
