Hello all.
I got my CAM program (MecSoft VisualMill) outputting G code that works for circular interpolation. I made up a test program and tried it out, and it worked great on both clockwise and counter-clockwise arcs.
Here's the problem: it only works in G54/E01 offset. If I try running the same program in G55/E02, as soon as it gets to the arc line it just stops with no error. The spindle keeps spinning and the coolant keeps flowing, but the movement stops and the program will not continue. The file is exactly the same except for the fixture offset.
Here is the format of the output:
G17
G03 X5.2500 Y0.0000 R1.0000 F60.
G02 X-5.2500 Y0.0000 R5.2500 F80.
Is my problem the radius output instead of the I,J output?
Any help would be greatly appreciated.
Thanks,
Jon
