My company is in desperate need of some CAM software and cambam will suit all our needs, i have trial version but dont have a clue where to start linking it to machine.
Help would be MUCH appreciated!
Thanks,
Jack
Thanks,
Jack
I think Cambam is only CAD/CAM software. You can draw a part and create the gCode but you'll need controller software to actually run the code on your machine. Lost of people use Mach3 for controller.
Gary Shepherd
www.16tracks.com
We have a Bridgeport Series 2 MDI with heidenhain tnc 145. I am aware people have linked cambam with tnc 151 i just dont have a clue where to start!
I've not used CamBam, but generally you tell your CAM software to use a postprocessor to convert the machining operations you create into G-Code commands that the machine controller would understand. CamBam is supposed to have very good tech support, so you might try contacting them and see what they suggest.
Mike
thanks mike i will give them a ring!
You need to load the Heidenhain server software on your PC and then CamBam interacts with that and controls the machine.
good info, including downloads, on the Cambam forum: Heidenhain TNC151 Conversational
