587,421 active members*
3,181 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > 2nd Parallel Port for Z Axis - No Go
Results 1 to 10 of 10
    May 2011
    92
    Installed a Rosewell RC304 PCI card in PC, using only the 1 port. Using CW8060 driver and 5 axis USB 5v BOB.
    This is only for the 1200ozin Z axis.
    PC parallel port(printer port) LPT 1 is connected to a Gecko 540. For X,Y,A.
    Ive tried both LPT ports 2 (2070) and 3 (2060) in Mach 3. No stepper movement. It does have current.
    Then ckd pin #7, Z axis DIR, end of the cable coming from PC 5v. But when I hit up/down keyboard arrow keys, still get 5v.
    Tried Mach3 Z jog buttons, I have a touchscreen, still 5v.
    Shouldnt I get 0v using either keyboard or jog ?
    Mach3 setup- Z ckd, Pin 6, Pin 7, ckd, ckd, 1, 1.
    Feb 2007
    4553
    Post Re: 2nd Parallel Port for Z Axis - No Go
    kNucklBustr,
    Did you define the I/O range correctly in Mach3?
    The device manager will provide the necessary address information.
    See attached images for details.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    May 2011
    92
    Yep. The first number in LPT2 address is 2070, LPT3 2060.
    I have Enable Legacy ckd.
    Running XP, SP2.
    LPT 1 , printer, for the Gecko is 0378. Which is ok.
    Im wondering if the hotkeys arnt setup for this keyboard. There is no page up/page down on it.
    Still... Mach3 jog z+ and z- should work.
    Feb 2007
    4553
    Please confirm the port address is the same as the attached image:
    Jeff...
    May 2011
    92
    Yes 0X 2070, also used 0X2060. The PCI card has 2 connectors, the 2nd ribbon cable is not hooked up.
    The 2 show up in device manager.
    Feb 2007
    4553
    is 5 volts d.c. connected to cp+ and cw+ on the CW8060 driver?
    May 2011
    92
    Not at equipment, but heres how its wired. Ill re-ck later for 5v.
    CP+ Com
    CW+ Com
    CP- Step
    CW- Dir
    Feb 2007
    4553
    Quote Originally Posted by kNucklBustr View Post
    CP+ Com
    CW+ Com
    CP- Step
    CW- Dir
    Your wiring is incorrect if com is not +5 volts
    Many breakout boards have a "com" selection jumper that has a option for +5 volts or ground. If yours does not have the + 5 volt option connect CP+ &
    CW+ to the power supply +5 volts.
    Jeff...
    May 2011
    92
    Using LPT 3, BOB 2 led lites on, not connected to Driver, I get this from the BOB terminals:
    EN 0v
    Step 5v
    Dir 5v
    Com 5v
    The BOB does have an optional J1 to solder in a jumper 5v , Gnd.
    The BOB uses a USB cable to provide 5v in use.
    Feb 2007
    4553
    Check your private messages.
    Jeff...
  1. x axis not working with new computer/parallel port
    By lowfronty in forum Mach Software (ArtSoft software)
    Last Post: 06-03-2014, 09:52 AM
  2. Replies: 0
    Last Post: 10-28-2013, 05:12 PM
  3. 5 axis G540 +1 with a single parallel port
    By dmauch in forum Gecko Drives
    Last Post: 08-05-2013, 08:51 PM
  4. 3 axis Bi polar with parallel port?
    By Techbuilder in forum Open Source Controller Boards
    Last Post: 04-21-2009, 09:29 AM
  5. CamPod a USB to Parallel Port Three Axis Step Generator Available
    By Dennis Bohlke in forum News Announcements
    Last Post: 02-21-2006, 07:49 PM
