Re: Derming proper timing pulley ratio with stepper?
That driver delivers 7A peak or 5A RMS. Your Z stepper will be driven at almost half power.
It looks like the stepper inductance is 5A which is not too bad for one of the big ones. It will make almost full power up to around 200 RPM or 40 IPM.
It will lift about 3200 pounds peak with a 5 TPI ball screw at 8.3A if you had a driver that would do that.
With a better driver like a Gecko you could go 1 to 1 and not even run a spring.
I would run a spring and you can get 80 IPM fairly easy with a 1 to 1 ratio.
youtube videos of the G0704 under the name arizonavideo99
