Need help with thermostor error in spindle drive varispeed 626vm3c cimr-vmc23p7
Hello everyone
I am reconditioning an old hitachi ht 25g. Variseed 626vm3c has been used to control the turret motor. I continuously get an error F-902. Since i am using encoder control, the connector 2CN is not used. Acccording to the manual, thermistor inputs have to be given to pins 8 and 9 of 2CN. I tried giving the input to those pins but the parameter V7-1 still shows temperature of -27 degree C. Apparently i somehow need to get this above -10 to get the drive to work. If anyone else has used encoder control and has been able to run the motor, please do let me know the connector and pin numbers where you connected the two thermistor wires. I just need to get the parameter V7-1 ro read something above -10 degree C.
Thank you in advance !
Experto Crede Machines Private Limited
www.expertocredemachines.com
