587,787 active members*
2,465 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > haas c5 4th not working kinda
Results 1 to 4 of 4
    Aug 2011
    77
    ok have older haas 1999 have a hrt 210 we use all the time bought a c5 haas indexer plunged it in changed setting for it im parameters and nothing ??
    out of curiosity i changed parameters back to the hrt 210 and it works but the rotation is off i assume because of the different gear ratio
    so i assume the unit is good nd i am doing something wrong?
    a haas tech told me to just run it as the hrt 210 and change a parameter to change the rotation to match so when it does one revolution it reads 360 degrees
    but dont know what parameter it is
    thanks for and help
    Aug 2004
    782
    Re: haas c5 4th not working kinda
    Check with your hfo asap.
    Iirc, the new ones have a different servo, and the compatibility is not the same.
    The old servos were 2k count, and the new ones are 10k. The amps (drivers) are different, and something else changed as well, iirc.
    Feb 2010
    1184
    Quote Originally Posted by redridertwo View Post
    thanks for and help
    You got lousy advise and I would seriously reconsider letting that tech work on any of your equipment. DO NOT change your 210 parameters, espescially if your 210 is working fine.
    As already stated, call your HFO and give them your exact model of indexer and have the serial number handy also. They will direct you what setting to use for your model of indexer (there are several that are similar). If it is still not working, you will need to change parameters for for the 5C until it does. Then you can seamlessly switch from 210 to 5C without issues.
    Good luck!
    Mar 2010
    1852
    There are different parameters for different units. The attached pages are from Haas for my 1997 VF-2 running 2000 software. I laminated them and keep them in my manual.
    One page if for brush rotarys on Brush machines and the other is for brush rotarys on Brushless machine.
    Mike
    Attached Thumbnails Attached Thumbnails Rotary Parameters.pdf
  1. Replies: 11
    Last Post: 09-14-2018, 07:10 AM
  2. Haas expert, now working with Mazaks
    By tom465 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-25-2010, 05:45 PM
  3. (kinda) New here
    By Vortex_bits in forum Australia, New Zealand Club House
    Last Post: 03-05-2008, 07:50 PM
  4. 2UVR x-axis powerfeed sorta kinda working
    By Stinson_Voyager in forum Tree
    Last Post: 01-14-2007, 08:11 PM
  5. 2UVR x-axis powerfeed sorta kinda working
    Last Post: 12-27-2006, 06:10 PM
