587,490 active members*
6,116 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need help choosing a VFD-confused newbie
Results 1 to 5 of 5
    Apr 2014
    2
    Hey guys, I am building my first CNC router in my garage and purchased a Chanzhou HuaJiang Electric 3KW Air-cooled spindle.
    http://www.huajiang.cn/english/pro1.asp?cid=18
    I set out to buy a VFD for this spindle and am having some trouble. My garage has 220V single phase but it seems that the VFD's at that level require 3 Phase. Is there a single Phase 220 VFD that would be compatible with this spindle? Should I sell this spindle and switch to a 2.2 KW setup instead?
    I'm really new to this so any advice or recommendations would be appreciated.
    Thanks,
    Q
    Dec 2003
    24220
    Re: Need help choosing a VFD-confused newbie
    That is around 4HP so you should be able to find a 240v 1ph in VFD.
    Look at the Hitachi range, fairly good quality price and support.
    Al.
    Albert E.
    Apr 2014
    2
    Hitachi seems to goto 3 Phase above 3HP. The only one I can find that goes higher at 1 phase is this one but I can't see the brand.
    4KW (5.5HP) NEW Variable Frequency Drive Inverter VFD | Automation Technology Inc
    Is this a good one?
    Q
    Dec 2003
    24220
    That looks like the Huanyang, generally considered the bottom of the pile, if you want to take a chance, the cost is not that great, usually.
    But poor documentation and support.
    Al.
    Albert E.
    Dec 2013
    18
    If you're still looking for Hitachi I found this http://www.motionmarketplace.com/marketing/hitachi/
    Good Luck,
    -Frank
  1. Newbie - Having problem and I'm so confused
    By matinski in forum Mach Mill
    Last Post: 12-18-2012, 09:32 PM
  2. Newbie is very confused
    By talbrecht in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-26-2012, 12:34 PM
  3. Newbie with new machine confused!
    By redvanth in forum Chinese Machines
    Last Post: 08-27-2011, 12:35 AM
  4. Confused newbie
    By thumper650 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-29-2010, 05:15 AM
  5. NEWBIE!!! Confused with 3d Routering and Milling
    By Sanghera in forum Uncategorised CAM Discussion
    Last Post: 04-20-2004, 03:58 AM
