587,495 active members*
3,630 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 30 taper nmtb to r8 tormach collet.
Results 1 to 5 of 5
    Feb 2010
    3447
    I've seen adapters for 30 taper nmtb to mt3. Do they sell one to go to r8? I'd like to be able to use a few of my tools that are setup in tormach quick change holders without removing them and setting them up in a 30 taper holder. Would the holder adapter have a threaded screw inside for the r8?
    Feb 2006
    7063
    Re: 30 taper nmtb to r8 tormach collet.
    Just use a 30-taper ER chuck with a 3/4" collet.
    Regards,
    Ray L.
    Feb 2010
    3447
    Way to overthink things right... Hahahah!! Thanks as always Ray.
    Dec 2008
    740
    There are a couple of reasons why I wouldn't stack tool holders but it obviously depends on your exact application:
    Runout may be unacceptable - you can sometimes play with different orientations but usually Murphy ensures that components contributing to runout add up just when you would prefer them not to.
    I don't see how you could ensure that the TTS collar would press against the ER nut so you'll only be clamping on the shank. This is actually a good thing when considering runout (unless you have a nut ground perpendicular to the rotational axis) but bad when considering stability. Not only is this assembly prone to flex but I wouldn't be surprised if you'd have problems controlling the chatter.
    By all means try it and prove me wrong, but this isn't something that I would want to do.
    In my opinion you'd be better off buying a few spare end mills.
    Step
    Jun 2006
    2512
    You don't need a collet chuck and ER collet you can buy ISO30 collets that will directly perform the same job as the Tormach R8 collet. You may have to do some minor modifications like facing the end etc. Google ISO30 Collet.
    Phil
  1. Taper angle on ER collet?
    By Jonne in forum MetalWork Discussion
    Last Post: 08-02-2012, 12:51 PM
  2. Collet taper information
    By jwill171 in forum Uncategorised MetalWorking Machines
    Last Post: 08-26-2009, 01:20 AM
  3. NMTB 30 versus NMTB 40 Tooling
    By MrWild in forum Uncategorised MetalWorking Machines
    Last Post: 10-11-2007, 01:26 PM
  4. HF Mill NMTB 30 Taper
    By rodzilla in forum Benchtop Machines
    Last Post: 09-04-2007, 12:23 PM
