587,485 active members*
3,544 visitors online*
Results 1 to 5 of 5
    Feb 2011
    212
    limit switchesnot working ?
    I have an older IH CNC and everything seemed to work prior to me buying it. once I moved it to its new home the limit switches did not work.
    Quick rundown
    had a computer crash and had to replace it. Had to install the drivers and the backed up info in the new computer. could this be a setting that I need to adjust or install something ?
    I have been running everything with out offsets , so would be nice to be able to home this thing out and save offsets
    Feb 2011
    212
    Re: limit switchesnot working ?
    well it appears they are working I just need to get the mach 3 reconfigured
    Jun 2013
    41
    Please feel free to give us a call tomorrow for some assistance with the configuration. If that is the issue, it shouldn't take long to straighten out the problem.
    203-562-0699
    Feb 2011
    212
    Thanks ^^^
    Feb 2011
    212
    I ended up figuring it out with the auto set up
  1. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  2. Y and Z limit switches inputs not working
    By Lasr Da Vinci in forum Hobbycnc (Products)
    Last Post: 06-18-2015, 11:33 PM
  3. Replies: 3
    Last Post: 09-30-2013, 08:55 AM
  4. Limit Switches Not Working ?
    By Redline in forum Xylotex
    Last Post: 12-13-2008, 03:43 AM
  5. Working with MDF
    By Miguelflores in forum Material Machining Solutions
    Last Post: 03-16-2008, 10:45 AM
