587,462 active members*
3,228 visitors online*
Results 1 to 11 of 11
    Jun 2014
    22
    Cutting taper on TL-1
    After going through the IPS and researching online I cannot find information on how to cut a taper on the TL-1. I may have to manufacture a taper pin for work in the next couple of days and would appreciate if someone can point me in the right direction.
    AJ
    May 2013
    142
    Re: Cutting taper on TL-1
    Program it like you would if it wasn't tapered then add an X end point on the same line as your Z end point.......
    Jun 2014
    22
    Thanks. Would this would be done in the IPS on O.D. turn tab or maybe OD Chamfer?
    May 2013
    142
    I forgot IPS generates OD and Face operations as canned cycles. My previous advice is invalid in that case. I don't use those canned cycles but I know the Haas manual explains them pretty well.
    Jun 2014
    22
    Thanks anyway Billetgrip. I cannot find anything in the manual in regards to cutting a taper other than chamfers. May have to give Haas a call.
    Dec 2011
    295
    Canned cycles are the same but you would use U instead of X (as x would be the start dim discribed on the previous line and would not affect the U dim) on a line by line case. If you want the whole part tapered use the tool offsets/taper page.
    Jun 2014
    22
    Thanks LeWhite. Hopefully I'll have time to get on the lathe this week. I didn't realize there is a tool offsets/taper page. I'm also not sure what you mean by using a U instead of X. What is the U dimension?
    May 2013
    142
    U is the incremental of X.
    Dec 2011
    295
    As you know different L/D will have different tapers as well as distance from chuck. To use tool taper page tapers the whole tools operation. Using U (delta X) just tapers that line.
    Dec 2011
    295
    Quote Originally Posted by LeWhite View Post
    As you know different L/D will have different tapers as well as distance from chuck. To use tool taper page tapers the whole tools operation. Using U (delta X) just tapers that line. Unlike mill G91, U is non modal.
    Dec 2011
    295
    Unlike mill G91 U is non modal.
  1. cutting a taper on titanium rod
    By marty7001 in forum MetalWork Discussion
    Last Post: 05-21-2014, 02:06 AM
  2. Cutting 20 deg. Taper in Mits FA20s
    By Toolz in forum EDM Discussion General Topics
    Last Post: 10-20-2011, 12:29 PM
  3. Lathe cutting a taper
    By eartaker in forum Mini Lathe
    Last Post: 01-24-2011, 07:45 AM
  4. help with cutting a inverse taper angle
    By redfoxbody11 in forum Uncategorised MetalWorking Machines
    Last Post: 11-12-2010, 01:10 PM
  5. taper thread cutting
    By cncmc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-05-2008, 10:59 AM
