I have recently purchased a preowned NM200 Pro-series 2010 model and could use some help on one of the issues I'm having. The machine is in good condition despite a good portion of the paint being gone, bad spindle bearing , and the need for a new x axis ballscrew assembly. I have dismantled a good portion of the machine but did run some dry cutting programs and the machine, seems for the most part in decent shape. One issues is that the spindle only rotates CW , even if I give it a M04 command, it still turns CW. I have used Mach3 only on the tormach I have which is for the most part preconfigured and there is not much you can do to the settings. I've followed this forum for a while and looking forward to bringing the machine back to a good operating condition. Also, I've noticed the original spindle and VFD seem really low on torque, I had the spindle running at 400rpm and was actually able to stop it with my hand. I'm looking to do the upgrade to the C300 VFD and new motor , but is it normal for this particular model to have such low torque? Thanks .
Blake
