Can I use 10-30 volt N/C NPN prox sensors with the parallel port if I tie the computer 5V ground to my 24V ground?
Oops I meant FOR home/limits in the title.
If they are true Open Collector, you may get away with a 10k pull up from collector to PC 5v+.
Al.
Albert E.
You could also use these $10 hall effect sensor/switches. Just need a little steel vane to slide through the slot and actuate. one wire for ground, one wire for +5 to 30V and one wire direct to open collector output. Nothing else needed.
Couldn't be easier.
I also use this for spindle speed sensor. They are not swarf sensitive, as the tiny magnet is internal and there is no detectable magnetism on the surface.
http://www.digikey.com/product-searc...3-ND&x=12&y=14
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
Sorry! Forgot the link:
SR17C-J6 Honeywell Sensing and Control | 480-1993-ND | DigiKey
CR.
Aren't those normally open? if so, I wouldn't use them for limits.
Edit: Or does this mean they would be N/C-
"•Operated by a "Ferrous Vane" interrupter for pulse counting or position sensing""
I found a 4.8-30 VDC prox switch on the UK ebay site. Any reason this shouldn't work?
SN04-N 4mm Approach Sensor Inductive Proximity Switch NPN DC 4.8-30V 500mA | eBay
Looks like they should work?
Al.
Albert E.
