I am having one more problem with my setup and i am looking for some input,
I have a old cnc router table that i have upgraded the controller and when ever the spindle comes on the y axis with pluse/move so when i am cutting a circle it comes out as a spiral seeing that the start point and the end point are not the same. X and Z seem to be fine just Y. if i run the program without the spindle the Y Axis is fine and my start point and end point are spot on.
I have tried to change the +/- leads for the servos to a shielded wire thinking that it was picking up an interference same result. the encoder wires are already shielded
Machine Specs
Mach 3
Gecko G320x Drivers
C10 BOB
55V Power supply
Servos (Reused from old setup *replaced encoders*)
US Digital E5 Encoders
C41 PWM Spindle controller
Perske Spindle (Reused from old setup)
Delta VFD (Reused from old setup)
C4 Charge Pump (used as safety switch)
thanks
Mike
