587,496 active members*
3,550 visitors online*
IndustryArena Forum > CAM Software > CamBam > Just the donut; not the hole.
Results 1 to 3 of 3
    Jan 2015
    1
    As part of a project I'm trying to pocket out what is essentially a ring. But I can't seem to figure out what the correct process is to have it exclude the middle section. I've tried to distill the issue down and the following is the root of what I'm trying:
    In CamBam create a circle. Next create a smaller circle inside the original one (creating the aforementioned donut). Then pocket out just the donut part.
    That last part is what I can't figure out. I assumed Edit --> Subtract would be what I need, but either it or I isn't working right. If the two shapes intersect then Subtract seems to work as expected, but since these two don't overlap, I'm at a loss.
    Any help would be greatly appreciated.
    Nov 2008
    412
    Re: Just the donut; not the hole.
    "Any help would be greatly appreciated."
    Why don't you post this on CamBam website, Guys there are really quick with answers.
    Forget about global warming...Visualize using your turn signal!
    Nov 2010
    520
    Something like this
    It is really simple. Just draw a circle and put another circle inside. Select both circles and click on the pocket MOP. Done.
    And the CAMBAM forum is really helpful.
  1. moving hole made using hole wizard SW2011
    By themotorman in forum Solidworks
    Last Post: 11-16-2014, 05:51 PM
  2. Replies: 9
    Last Post: 09-18-2012, 12:11 AM
  3. Replies: 18
    Last Post: 03-21-2011, 11:28 PM
  4. Thermal Forming a Donut Shape
    By mulling in forum Vacuum forming, Thermoforming etc
    Last Post: 12-21-2009, 11:27 PM
  5. Free Donuts on National Donut Day Friday June 5
    By joeybagadonuts in forum News Announcements
    Last Post: 06-03-2009, 07:00 AM
