587,188 active members*
4,546 visitors online*
Results 1 to 4 of 4
    Aug 2005
    43
    V2XT Zeroing Z-Axis
    I've been playing around with a V2XT and can't seem to figure out how to zero the Z-Axis at the top of the part? I have tried Set_X_Y_Z and it dosn't seem to change anything. Any help would be appreciated.
    Bob
    Home
    GO-Tech: Geek Show&Tell Meets Ann Arbor 2nd Tues at www.maker-works.com
    South East MI cnc meets 1st Wed at www.maker-works.com
    Aug 2010
    48
    "Z" axis zero should be dependent on the tool height setting...no? Or are you looking to do something else?
    Aug 2005
    43
    Hi SS_again,
    Thanks for the reply.
    Yeah I understand that the tool height settings are part of the program, but all I want to do is stick a tool in the mill, touch off the top of the part and set Z=0 for that tool. I can do this in my shop using Mach3 and EMC2. But the vx2t is at my cousins shop and I just use it when I need a big mill.
    Can I do this or do I have to pick a tool as a default (zero tool) and then set my tool relative to the default tool?
    Thanks,
    Bob
    Home
    Aug 2010
    48
    Each tool has its own zero to set.
  1. Haas SL30 B-axis Zeroing
    By Swilliamscnc in forum Haas Mills
    Last Post: 02-21-2011, 07:36 AM
  2. Zeroing A Axis
    By findor in forum G-Code Programing
    Last Post: 10-30-2009, 11:59 AM
  3. Trouble Zeroing A axis
    By MBG in forum Haas Lathes
    Last Post: 03-16-2009, 12:04 AM
  4. QT-28 t-32 X-axis re zeroing help needed
    By Fred Raud in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-31-2008, 08:28 PM
  5. Strange results when zeroing z axis
    By millbilly in forum Mach Mill
    Last Post: 06-29-2007, 07:49 AM
