587,784 active members*
2,611 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > New Powermax 85 w/machine torch questions?
Results 1 to 12 of 12
    Mar 2012
    140
    I just ordered The Hypetherm powermax85 with the machine torch, model# 087115. Does anybody know if that model comes with the CPC connector already installed.? OR do i need to order that seperately?
    I talked to Tom Caudle today and he seemed to think that it did but he wasn't 100%. I already have the Bladerunner 620-4 controller and I just ordered the mic01 connector cable from Tom. Just want to make sure I got everything to finally get my Plasma table running.
    My build log is over in the build log section, if you want to read about my tribulations trying to get a noisy chinese machine to work with my table and the Candcnc controller.
    Jim?
    Nov 2009
    159
    Why yes it does come with that CPC card and interface. The interface should be set to 50-1 ratio. The PWM box may be set to 7-1 ratio. You should take the 4 screws off the bottom of the PWM box and verify before you hook it up. We just installed one of those this afternoon on a 5x10
    Now featuring Plasmaland online
    Mar 2012
    140
    Thanks. I thought I had read somewhere that it did but I couldn't remember where. Are you cutting parts yet? Are you using Candcnc controls?
    Mar 2011
    CandCNC recommends you set the PWM box to 20:1 ratio and remove the cover on your new PM85 and set it to 20:1. It comes set at 50:1. That's what I did and it works perfect.
    Mar 2012
    140
    Quote Originally Posted by travmc1 View Post
    Thats good to know. I should have the PM85 by next weekend. It should be a breeze to hook up compared to what I've been dealing with.
    Mar 2012
    140
    Any body have the machine torch for the PM 85, I think it's model # m85 ? What is the diameter of the torch body? I'd like to make the torch holder for it while I'm waiting for it to show up.
    Jun 2010
    41
    I have a pm 85 with machine torch diameter is 1 3/8 inch my holder has a notch for the gear rac to clear the rak is 1/4 inch wide and runs 8 of the 12 inchs down the back side of the torch.
    Mar 2012
    140
    Quote Originally Posted by miles peters View Post
    Thanks Miles: How long is the torch body overall, give or take...?
    Jun 2010
    178
    Mar 2012
    140
    Thanks Dude, some excellent reading material while I'm waiting for my machine to arrive.
    Jan 2008
    2247
    You can remove the torch mounting sleeve to shorten the torch as well...here is a pic of mine.
    Jim Colt
    Quote Originally Posted by xalky View Post
    Mar 2012
    140
    Yes, I found that out when I went to order my machine. I originally wanted to order the machine with the short torch and they explained to me that the long torch can be shortened. It's nice to have options. Right now all my cables will be supported overhead for its simplicity but I might eventually go with a track system for wire management. Right now I just want it to run. :-)
    Sent from my SPH-D700 using Tapatalk 2
  1. Powermax 85 Machine Torch, any breakages?
    By BioHazard73 in forum Hypertherm Plasma
    Last Post: 09-01-2012, 09:30 AM
  2. Powermax 65 machine torch on Torchmate 2
    By FunWestTexan in forum Hypertherm Plasma
    Last Post: 01-18-2012, 03:39 PM
  3. Machine torch for Powermax 600/800/900 for sale
    By jasonpaulbauer in forum Hypertherm Plasma
    Last Post: 12-14-2011, 04:44 PM
  4. CandCnc + Powermax 45 + Machine Torch =
    By brouser1 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-09-2010, 10:27 PM
  5. Hypertherm powermax 1000 and machine torch
    By Mongkol in forum Waterjet General Topics
    Last Post: 06-22-2008, 06:57 AM
