587,380 active members*
3,328 visitors online*
Results 1 to 3 of 3
    Jul 2014
    1
    Epoxy casting questions
    Hello, this is my first post here. I found this forum while looking for information on epoxy resin uses.
    I am hopping to mold and cast some ABS RC car parts out of Epoxy resin and wondering what type of epoxy fillers would be best for my application. This is only for my personal use and not for any mass production.
    There are a few gears that I would like to make but most of the other parts are things like shock towers, hub carriers, a arms etc...
    I was thinking about using chopped carbon fiber or kevlar pulp as an epoxy filler but am open to pretty much any kind of filler that would work well. I unfortunately can not use carbon fiber cloth because the parts are to detailed. What do you think would be the best filler for this kind of application? would any filler produce a reasonable part out of casting?
    Apr 2004
    5747
    Re: Epoxy casting questions
    Any filler you use will increase the viscosity of the resin, making it flow poorly and tend to bridge over indentations in your mold. So if you really need to use it, you'll have to experiment to see how much you can get away with before it won't fill your mold adequately.
    Andrew Werby
    Website
    I highly recommend you take some time and go read all the information on this site.
    Its very very ensightful
    Guerrilla guide to CNC machining, mold making, and resin casting
  1. Replies: 71
  2. Replies: 9
  3. Questions about aligining, squaring, paralleling, self-leveling epoxy
    By Dman65 in forum DIY CNC Router Table Machines
    Last Post: 09-15-2011, 05:14 PM
  4. Resin casting project questions!
    By granth3 in forum Moldmaking
    Last Post: 09-28-2010, 05:15 AM
  5. Casting Iron Questions
    By TomHouston in forum Casting Metals
    Last Post: 02-13-2008, 04:05 PM
