587,550 active members*
2,902 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Rewiring keling 1100oz servo
Results 1 to 5 of 5
    Apr 2014
    345
    Does anybody know if its possible for me to solder on new thicker shielded wires into my servo motors? The wires that came with it were cut short and are not shielded and are just crappy wire. So I'm wondering if anybody has changed this wire out for their own? Also how would I go about doing it.
    Feb 2007
    4553
    Re: Rewiring keling 1100oz servo
    Ianagos,
    Squeezing or pinching the strain relief with needle nose vise grips will release the wire & strain relief, then remove the screws that hold the end cap on.
    Using the original strain relief may be difficult if the replacement wire diameter is to large.
    Worst case scenario a different style (larger) nylon dome strain relief connector may be able to be retrofit.
    YMMV
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2014
    345
    Ok we'll how are the wires attached inside? Would it be too difficult to rewire it?
    Feb 2007
    4553
    They may be crimped or crimped and soldered.
    Its a tight fit in there however with a bit of patience it can be done.
    Jeff...
    Apr 2014
    345
    Min were crimped and soldered I opted not to mess with the others after messing with one. So I just did a splice and crimped and soldered it all together
  1. Replies: 158
    Last Post: 12-08-2014, 05:41 PM
  2. New Keling DC servo - won't stop..
    By Spinnetti in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2012, 02:12 AM
  3. wondering about Keling servo feedback cables?
    By aaronwelder in forum Automation Technology Products
    Last Post: 10-25-2009, 03:00 AM
  4. Keling servo as Taig spindle motor replacement?
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 08-18-2009, 11:41 AM
  5. Keling cnc NEMA 23 Servo package experience
    By schwinndk in forum Automation Technology Products
    Last Post: 06-23-2009, 09:42 AM
