587,299 active members*
3,675 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > EZCad2 "Not Ready" issue to OMTech 30W Fiber Laser
Results 1 to 9 of 9
    Feb 2022
    1
    Post EZCad2 "Not Ready" issue to OMTech 30W Fiber Laser
    Hello everyone, I am new to this forum and need to see if I can get some help. I was able to download the driver so my Ezcad2 is not in Demo mode. However, when trying to do just a simple shape to test out laser the laser will "red" button will work fine and outline the square but the "mark" will not work. There is a red light that say not ready on the bottom. When I try to press it to see if it will give me information on error issue but it does nothing. Has anyone encountered this and if so any suggestions? I appreciate any help, thank you.
    Mar 2022
    1
    Re: EZCad2 "Not Ready" issue to OMTech 30W Fiber Laser
    I too have this same problem, anyone have a solution?
    Mar 2022
    3
    <p>
    Maybe you could try the <a href="https://www.laserchina.com/download/ezcad/" target="_blank">latest EZCAD2 software </a>at the official site.
    </p>
    Mar 2022
    2
    I also have this problem, someone please help. I just spent way too much money on this damn laser for it to not work lol
    Mar 2022
    2
    OK, so I figured it out, go into System Parameters/Param, click Ports, change 'Door IO - Input Port' to NULL. Button should now show READY and will work
    Apr 2022
    3
    Quote Originally Posted by 1kxl View Post
    Is this thread still active?
    I followed the answer here and my door IO and input port are not the same as this any advice.
    My buttons are output IO Mask Output IO Mask
    Apr 2022
    3
    My buttons are input IO Mask Output IO Mask I changed them to null.
    Is null mean zero is checked or is it all are unchecked. Thanks in advance
    Apr 2022
    3
    Mar 2024
    4
    Smile Re: EZCad2 "Not Ready" issue to OMTech 30W Fiber Laser
    I got the same issue.After changing the IO setting, the problem is still there.
  1. Raycus 30w Laser Software EZCad2.0 Calibration
    By LaserCutter2019 in forum Laser Control Software
    Last Post: 09-24-2020, 06:56 AM
  2. 1 kW Fiber laser machine "without cover"
    By cevdet in forum Fiber Laser Cutting Topics
    Last Post: 02-11-2019, 11:01 AM
  3. Replies: 0
    Last Post: 12-15-2015, 08:01 PM
