587,772 active members*
3,068 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc 15m program overwrite parameter
Results 1 to 9 of 9
    Jul 2007
    19
    I am running a fanuc 15m controller on a Toyoda FA550 machine. I am loading programs through the RS232 port using Gibbscam software. Each time I re-process a program in Gibbs, it assigns it the same program number, and unless I delete the program in the fanuc memory before I send the program I always get the alarm: already exists. On the other fanuc controllers that I run there is a parameter that can be set to automatically overwrite the program. I assume it is the same with this controller. Can anyone tell me what I need to reset to correct this?
    Jan 2006
    121
    Looks like parameter 2200 bit#1 (2nd bit from right) need to be set to 1. It will override the existing program with new one.
    Jul 2007
    19
    Talking
    Thanks so much. I will try it when I get to work today.
    Nov 2008
    9
    Is there a similar overwrite parameter for the 180i control? I am doing the exact same thing with our machine, and I have to delete all of the subprograms every time I send a new program to the control.
    Jun 2008
    1511
    It should be parameter 3201.2
    Stevo
    Nov 2008
    9
    It worked great! Thanks!!!
    Jun 2008
    1511
    Your welcome.
    Stevo
    Nov 2008
    9
    Re: fanuc 15m program overwrite parameter
    OK, I'm going to revive an old thread here. I am having basically the same issue with a new machine that we have. Is there a parameter to adjust, or another way to overwrite a program number that is currently active from the data server? I have changed parameter 3201.2, but it still will not overwrite a program that is active. We are running a Fanuc MXP200-FB control on a YCM vertical mill, and transferring using Firezilla ftp software. Thanks in advance for your help again!
    Jun 2008
    1511
    Quote Originally Posted by btdmfg View Post
    I think that model is an Oi control so 3201.2 should work for you. What program number are you trying to load? It may be that the program you are trying to load is protected…which will give you the same alarm.
    Parameter 3202.0 locks programs 8000-8999
    Parameter 3202.4 locks programs 9000-9999
    There is also 2 parameters that can be set to lock a range of programs but I don’t have the Oi manual with me to verify what those numbers are. As an example one parameter would be set to say 100 and another set to say 150 and this would protect the programs from 100 thru 150.
    Stevo
  1. Parameter for using G68 on Fanuc 11M
    By 4thaxismachine in forum Fanuc
    Last Post: 01-02-2024, 03:47 PM
  2. Replies: 6
    Last Post: 05-24-2017, 02:13 AM
  3. Set parameter from program....?
    By REVCAM_Bob in forum Fanuc
    Last Post: 01-10-2015, 11:39 PM
  4. Fanuc o/t parameter help
    By JimOtoole in forum Fanuc
    Last Post: 03-31-2009, 03:38 PM
  5. Fanuc 18T program/parameter question
    By mikeyson in forum Parametric Programing
    Last Post: 10-06-2008, 06:30 PM
