587,431 active members*
3,026 visitors online*
Results 1 to 2 of 2
    Feb 2017
    11
    Alphacam POS SCM Xilog3 3d Surface xyz
    $----------------------- MACHINING FEED MOVES -------------------------------
    $40 Machining FEED lines
    $MODAL OFF X Y Z
    $IF ABS(IZ)>0
    $ELSEIF FF = 1
    C[TC]
    G0 X=[CX] Y=[CY] Z=[CZ] V[RAPID_FEED] S[S/1000] T[T]
    G1 X=[AX] Y=[AY] Z=[AZ] V[F]
    $ELSE
    $ENDIF
    This are correct for 2d machine but don't work on surface machice in SCM 3xis xilog
    Someone Help me.
    Feb 2019
    7
    Re: Alphacam POS SCM Xilog3 3d Surface xyz
    Dear,
    i think i have same problem.
    You need make some Z interpolation or work on 3D surface?
    Which post for alfa you have and which machine?
