587,743 active members*
3,062 visitors online*
Results 1 to 4 of 4
    Apr 2013
    24
    Tool size problem ;-)
    I have something weird with my solidworks and solidcam
    when I design for example a 10x10 cm box in solidworks and go to solidcam and try to engrave with a 6mm (or another size) tool, the tool in the simulator is a lot bigger than 6mm more like 6cm.
    How do I fix that?
    Thx!
    Oct 2012
    60
    Is it possible you chose the wrong units for your part? I'm not sure what effect this has as I only ever design and machine in inches.
    Nov 2010
    set unit as millimeter. go to option-document property-unit-mmgs try that
    Apr 2013
    24
    Quote Originally Posted by sshroff100 View Post
    Thank you!
  1. tool size compensation - I think?!?
    By mmcp42 in forum Coding
    Last Post: 06-07-2013, 01:48 PM
  2. tool size concept- tool path generated vs gcode
    By kjl-pdx in forum Mach Mill
    Last Post: 03-12-2013, 07:25 AM
  3. Tool Size Settings?
    By tempgp in forum Uncategorised CAM Discussion
    Last Post: 03-08-2012, 10:58 AM
  4. tool dia. resolved still have size issues
    By Mark Stehr in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2011, 02:54 AM
  5. Dremel tool drillbit size ?
    By deleteallusers in forum DIY CNC Router Table Machines
    Last Post: 01-30-2007, 08:37 PM
