587,482 active members*
3,420 visitors online*
Results 1 to 3 of 3
    May 2015
    Exhaust Issues, building smells.
    Hey everyone, Im going to try and pack in every last bit of information I have that can help possibly answer my dilemma here.
    I began working at the place im at about a year ago now. We have two lasers here..
    1. Hurricane CO2 Laser Cutter 4' x 5' Table.
    2. Trotec 300 Fiber Engraving laser
    Over the winter we had a few issues with what seemed to be the acrylic gas's not exiting the building. Upon some reviewing I thought I had figured out the problem and everything began running smoothly, with no smells or complaints from anyone in the building. I used to work as an Auto Technician & Body Man so these smells really don't phase me but everyone else seems to get terrible headaches and are just miserable throughout the day when I have to cut something out on the Hurricane.
    Our exhaust system is as followed (please bear in mind im just going by what I can physically see, i am no HVAC specialist or anything nor was i around when the system was installed)
    I have some absolutely terrible sketch of the setup, i am attempting to draw it on paint so i can save it and post it here. so far im failing.
    Every unit I have EVER seen has a simple. simple Tube > Fan > Outside setup and these people have zero problems. My boss went out of his way and bought a BOFA AD1500IQ Fume Extractor. The BOFA is ONLY hooked up to the Hurricane laser. The Trotec & Bofa however push air to the SAME exhaust pipe. it comes to a "T" and then one big pipe (12"+) take the gas to the upstairs unit.
    The upstairs unit is a FANTECH SHR8004 Unit (Air Exchanger) the small room which this unit is contained it ABSOLUTELY REEKS of the acrylic gas
    Whoever installed the EXHAUST and New-Air Intake seems to be a fool to me. On the side of our building you can see (2) vents. One being the intake, one the exhaust. To my knowledge all exhaust venting should be directly out of the roof. Now, we are sort-of in a valley so i feel like the airflow is coming over the building, pushing the Exhausted air from the top to the ground and being sucked back in by the new air. (however i could be completely wrong, thats why im here!)
    Airflow numbers we are running.
    The BOFA is pulling a solid 600CFM, which was recommended by the guys at BOFA to clear the Hurricane laser bed.
    The FANTECH unit SAYS it pulls an average of 772CFM
    Is it possible that throughout ALL this piping, we are losing so much CFM that the gases don't make it through the FANTECH and outside?
    From back of the laser to the bofa there is roughly 36" of pipe the BOFA exhaust port to the Main Exhaust line is another 70" or so (mind you both of these have @ least 1 slight bend in them, they are the stretchy metal pipe.. i dont know the name, sorry) Mind you the TROTEC laser ALSO has a pipe thats roughly 70" bout only 4/5" diameter. now those two pieces of piping join into a roughly 4ft long section of what i think is 8-10" pipe, then from there it steps up to 12"+. The 12"+ Pipe is about 13 FEET long. From there it makes a 90 degree turn up, with another about 4/5 foot of square duct work it finally reachs the fan tech.
    Im sorry if i was all over the place and confuse anyone, im confused as heck myself and just want to figure this out!
    -Jesse
    Nov 2004
    69
    Re: Exhaust Issues, building smells.
    Remember that any piping on the exhaust side of the blower is pressurized. So if there are any leaks, the smelly exhaust air will escape.
    May 2015
    135
    I'm not familiar with the blowers you mentioned what cpm do they pull? I have two speedy 300 lasers on a 1550 cpm blower but it's a shorter run that you. Mostly engraving. Ideally I'd like to have a 2000 cpm blower to power the two. You've got a really big machine in the hurricane and its leaky, not as well sealed as the speedy 300. I'd estimate you need a 2500 cpm blower to go as far as you are with those two machines, maybe more, sounds like you have an overly complex and long setup. Eliminate all flex pipe, sounds like you have quite a bit of that. Flex pipe is complete garbage it hinders air quite a bit, and go 6-8 inch pipe or larger until you get right next to the machine or right next to the blower. Seal all connections with vac tape to ensure no air is leaking out which will help your throughput as well. Get a air flow meter from Amazon they are like $25, will help you measure the suction.
    Quote Originally Posted by APGLaser View Post
    -Jesse
  1. HPR 260 manual gas console smells like ozone.
    By millwright79 in forum Hypertherm Plasma
    Last Post: 11-07-2013, 01:50 PM
  2. Building my first CNC. How to solve accuracy issues...
    By c131fr in forum DIY CNC Router Table Machines
    Last Post: 05-24-2013, 08:22 PM
  3. Partner 5 spindle wont cw or ccw, smells
    By Brian FRF in forum Milltronics
    Last Post: 07-15-2011, 02:21 AM
  4. Something smells after about about 2 hours of cutting
    By Glidergider in forum DIY CNC Router Table Machines
    Last Post: 12-15-2007, 02:04 AM
  5. This coolant smells
    By pizzaman in forum MetalWork Discussion
    Last Post: 08-10-2007, 09:38 PM
