I'd like to know how the RichAuto controllers compare to Mach3?
I know both Laguna and Axiom use them is relatively high end small machines, seem like they should be good - are they?
Richard
Richard
I recommend use the Richauto controller .
I am in Los Angeles . If you need any help let me know .
I like Linuxcnc (but I have no experience with either of those.)
PS: it's free.
If the RichAuto still has all the Chinese symbols which you see in many videos, I would steer clear unless you are fluent in Chinese. Some of the DSP controllers have fully been converted to English others only partially. There are more and more controllers hitting the market. One of the most recent is the CentroidCNC Acorn controller. It cost $265 but it comes with some very tested software by a big name in the industry. It just got introduced and starts shipping next Wednesday. Check out their link. I have absolutely nothing to do with this company but there are many followers on cnczone, their bigger controllers that run the same software get mounted on many commercial machines. Worth a look.
Russ
Centroid Acorn CNC controller, Step and Direction 4 axis CNC Control board with ethernet communication
You might want to consider using UCCNC with the Axiom machines.
https://www.youtube.com/watch?v=KHKm-6MA2HQ
https://www.youtube.com/watch?v=bsJM7VH_apU
What would modification be required to run the Axiom with either UCCNC or Linuxcnc instead of the RichAuto?
I don't know what type of hardware is in the Axiom control, but you'd need to replace it with a CNC Drive controller (and breakout boards) for UCCNC, or a Mesa board for LinuxCNC (unless you are using the parallel port).
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
I'm not sure exactly what that means Ger.
Last year I replaced the stepper drivers in a Techno Davinci with Geckos and run it with Mach 3, would this be similar?
There should be a controller board in your machine, that the drives are connected to. You need to replace this board with a CNC Drive controller.
Gerry
I can control the external equipment by M-Code by Mach3 (for example: M7, M9) but I don't know how to do it by RichAuto.
Because the output signal of Rich Auto for lamp only.
Somebody, could you help me to control the external equipment by M-Code?
How to do it for OUTPUT SIGNAL Y7, Y8?
Thanks,
bonjour moi j,ai axiom pro6 2x36 et richAuto A11E et j'essaie de faire un update et me dis qu'il n'y a rien dedans auris'je supprimer sans m,en rendre compte mais je vois sur pc mais pas sur ma cnc comment faire pour avoir driver pour rich auto
