587,782 active members*
2,835 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF-2SS Tool Carousel Problem
Results 1 to 19 of 19
    Sep 2006
    251
    Good Morning Everyone. I am having an alarm # 942 (carousel timed out). It is too early for HFO to be open and I was hoping someone may have some insight. The 24 tool carousel will move clockwise ok, but will not move counter-clockwise. Thus, the alarm is generated. This is a 2006 machine and you guessed it, it's just out of warranty. If anyone has any insight, I am desperate with a hot job to get this running as quickly as possible. Thanks, JoBwan
    Feb 2007
    5
    Check the tool changer ToolChanger oil level. I had a similar problem on a machine but it was due the cold weather. I suppose that you are not in this situation but I will explain it anyway:
    The oil on the toolchanger was too tick due the low temp starting the machine early in the morning, just blowing warm air around the carusel with a hairdryer was enough to fix the problem.
    We ended up using a thinner oil for the toolchanger on that machine.
    Hope it helps!
    Ciao,
    Sandro
    Jul 2005
    12177
    I have had toolchanger problems because chips stick to the face of the proximity sensors that detect carousel position.
    There are two near the center on top of the carousel. They are difficult to see and get to but a crude way of flushing off any chips is just to spray all around the inside top of the mechanism with coolant.
    A few months ago I posted some pictures I took of the sensors on the 10 tool changer on a MiniMill the 20 tool changer is bigger but similar.
    http://www.cnczone.com/forums/showthread.php?t=22545
    Sep 2006
    251
    Thumbs up VF-2 SS Tool Carousel
    Geof,
    I have not seen any components that look like your pic's. This is a super speed and does not have an umbrella type tool changer. I have checked all of the proxi's that I am able to see with the covers off, to no avail. If I push the ATC Forward button, it changes tools perfectly. If I push the ATC Reverse button, then it alarms with nothing happening. Thanks for your inputs. I hope anyone out there can help with other options. HFO is really slow today for returning calls. Thanks again, JoBwan
    Jul 2005
    12177
    I was fooled by the word carousel. You have the side mount of course, I should have realised that with the VF2 SS.
    Have you turned the machine off and restarted it? My solution when I don't have the faintest idea what is going on. Crossing all available fingers when you push the power on button might help
    Sep 2006
    251
    Geof,
    Did that! Didn't help. I even crossed my toes. I just wish HFO would call me back. I'm getting a little frustrated and nervous on my timelines.
    Sep 2006
    251
    Lightbulb VF-2SS Tool Carousel
    Guys,
    I got her fixed and running on my own. Solution: I changed one of the relays on the I/O board and BINGO!!!! If I remember right, it was CR6. It's a little Omron 12VDC relay. Thanks and hope this helps some other souls out there in the future. JoBwan:rainfro: :banana:
    May 2006
    82
    Jobwan:
    i had a similar problem with a lathe rotation in one way was o.k in the opposite it wasn't. Because of production requirements i just recommend you to add to your program a few "dummy"(is it?) tool changes and just keep it runing in one direction untill HFO service tech have time for you.
    Dec 2006
    247
    Those relays will get you every time. I tore apart my lathe because everytime i called up a tool that was closer to rotate opposite direction it would alarm the cause was the ccw relay so I found and bought 10 relays everytime something goes wrong I change out a relay and it fixes the problem. Haas machines are notorious for relay problems.
    Joe
    Apr 2010
    Hi all the community: I have desided between a horizontal and a vertical carousel for Hass VF3, but not which is better of the two,
    Need to know, basically that each has different operational, maintenance and service life. The use will be given the machining center is for the manufacture of plastic injection molds all they can tell me about this type of tool changers.
    From already thank you very much everybody. Yours faithfully FAE
    May 2011
    HELP ME!!!!!
    hello. i have a bridgeport vmc 560 with 16 tools, i was having a problem with the machine but we can fixed, but we cant fix a problem with the tool changer.
    if some body could help me please!!!
    Aug 2010
    579
    Quote Originally Posted by mikemtz123 View Post
    (wrong)
    Post this problem in the Bridgeport Forum:
    Bridgeport and Hardinge Mills - CNCzone.com-The Largest Machinist Community on the net!
    Thanks,
    Ken Foulks
    May 2011
    HELP!!! I have the same problem.
    Quote Originally Posted by JoBwan View Post
    Guys,
    Would it be possible to help me the same problem? Carousel Position Timeout 942. I found this thread on Google and was hoping I could email you.
    Jan 2007
    107
    This alarm is caused when your carousel does not move to the correct location. When do you get this alarm? does your carousel move at all?
    May 2011
    During a tool change is when it happened. So I tried to do a "Recovery" and after following all commands it would give me the same alarm Carousel Position Timeout 942.
    Jan 2007
    107
    If the carousel does not move at all then I would look for a couple of things
    1. voltage to the carousel motor (It should be 160v)?
    2. the carousel motor belt is not broke?
    3. make sure the motor is not shorted
    Sep 2006
    251
    Sounds to me like it's possibly one of the 4 Omron relays on the I/O board.
    Just a thought tho!!
    Just a good ol' boy, never meanin' no harm.
    Joe
    Feb 2010
    1184
    +1 For the relays.
    Then move on to what Bryan said.
    May 2011
    Turned out to be the I/O board. Bought 4 new relays and still didnt work. Hass came and replaced the I/O board... $850.00 plus labor... ouch! But I'm up and running. Thanks for the help. New to the forum and I like it!!
  1. tool carousel position problem
    By Greg 24 in forum Haas Mills
    Last Post: 10-19-2009, 09:44 PM
  2. Problem in Tool change
    By ahmedsamy_81 in forum G-Code Programing
    Last Post: 02-14-2007, 04:02 AM
  3. tool carousel alignment
    By rubino2112 in forum DNC Problems and Solutions
    Last Post: 12-27-2006, 07:26 PM
  4. Spindle Bearing/Tool Carousel Motor???
    By AdvancedMfg in forum Charter Oak Automation Support Forum
    Last Post: 12-05-2005, 04:25 AM
  5. carousel, turret or magazine
    By mjiba in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2004, 11:07 PM
