587,784 active members*
2,478 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Work Fixtures / Hold-Down Solutions > Vacuum Fixture with Festo Vacuum Generators ?
Results 1 to 2 of 2
    May 2008
    157
    Has anyone used the Festo modular Vacuum generators to make vacuum bed to hold workpiece for CNC milling ?
    I have been looking around for simpler means of making vacuum fixtures which can use the shop air alone and i felt one can use the Festo modular vacuum generators with 0.45mm venturi nozzle and clamp the workpieces (medium sized once ranging between 100mm X 100mm to 300mm X 300mm).
    Has anyone out here tried this approach ?
    Thanks for all the help
    May 2008
    157
    Surprising that none of the folks here are able to answer this !
    Anyways i tried this and it worked successfully after some trials and errors and some fixing done
  1. Vacuum Fixture
    By jweinhold in forum Work Fixtures / Hold-Down Solutions
    Last Post: 10-11-2013, 07:57 PM
  2. Vacuum fixture trouble
    By theberg68 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-03-2013, 06:42 PM
  3. Vacuum fixture (vac source)
    By vtx1029 in forum DIY CNC Router Table Machines
    Last Post: 10-05-2012, 12:57 AM
  4. Vacuum Fixture HELP!
    By project5k in forum Benchtop Machines
    Last Post: 02-04-2009, 07:40 PM
  5. Pump for vacuum fixture
    By DAB_Design in forum DNC Problems and Solutions
    Last Post: 07-04-2004, 12:17 PM
