OK. So I designed a disc in solidworks, saved it as an .igs and loaded it into surfcam. The disc is a simple cut, I wanted to do a z finish pass just to zip the part out. (HDfoam) BUT, the cutter path wants to run on both sides of the surface and not ON top of the surface. I have all of the direction surface arrows in the right spot but.....? What am I doing wrong?
