Just wondering if there is a circuit diagram for wiring up optical interrupter switches? Switches i am using are these http://www.jaycar.com.au/products_uploaded/ZD1901.pdf
I am using a 5 volt power supply and a 100 ohm resistor on the Diode side with a pull up resistor between the collector and the battery. Just cant make it work
Thanks,
Ar
