587,905 active members*
3,640 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Lines disappearing
Results 1 to 7 of 7
    Jan 2013
    Lines disappearing
    We just started having this problem with our V.22,when the cursor is moved into the work area the lines of the drawing disappear they will not come back until you remove the cursor from the work area and scroll in or out. Its almost as if the drawing is hiding from the cursor. We have V.22 running fine on another box and it was working fine until a couple of days ago. Ive tried uninstalling and reinstalling the software but it doesnt help, thanks in advance for any assistance that might be offered...Jeff
    Jan 2011
    380
    It sounds almost like a video issue. Either with the video card (possible bad memory) or something with video driver. Have you updated any drivers recently on that system? And what system are you running? windows 7, etc?
    Jan 2013
    Its running 7,Im not certain if any new updates have came down on it,I thought maybe it was a video issue as well but havent noticed anything out of the ordinary in the video settings/drivers. It would seem if it was an update more users would be affected by the problem?
    Jan 2011
    380
    I remember now I had a similar problem with V24. I had to turn off windows desktop compositing. Was causing havoc with my system when I ran Bobcad. You can find it in control panel>system properties>advanced>performance. Just uncheck the box that says use desktop compositing.
    Give that a try and see. Other than that I'm out of ideas at moment
    Jan 2013
    Ill sure give it a try,thanks for your help.
    Jan 2013
    No joy there. There appears to be some files that are not being deleted on reinstall,not sure where they are hiding but they are involved in the preferences and settings for Bobcad. I tink if I could get a truly clean reinstall it may solve my issue,anyone know where the 'hidden'files are located?
    Dec 2008
    4548
    In V22, for me to get a clean install, I would delete the program files folder, then also the registry keys. Also, to get a good full clean install, I would delete both predators (and the key) to force the installer to jump through that hoop too. I dont remember, but I think the key was under HKLM back then, but I would look at HKLM "And" HKCU-Software-BobCad-Cam. BobCad would write Actual build keys.
    When you re-install, be sure to run the 1326 full installer, THEN the 1812 update to that...........
  1. My Disappearing Display
    By slowtwitch in forum Mikinimech
    Last Post: 01-13-2012, 04:57 PM
  2. disappearing soft key 18i-mb
    By ikennedy in forum Fanuc
    Last Post: 11-14-2011, 11:11 PM
  3. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
  4. Memory is disappearing. Why???
    By g-codeguy in forum Okuma
    Last Post: 04-21-2008, 05:53 PM
  5. Disappearing surfaces
    By Jim Estes in forum BobCad-Cam
    Last Post: 02-22-2007, 05:46 PM
