I have a task where I need to machine out a lot of light foam round-profile shapes on a Taig.
Easiest way seemed to set up the 4th axis and do side cutting. Which will work, but it's unnecessarily slow. My Sherline rotary table does something like 10rpm but the sanding cutter eats up the foam so fast it really could, and must, process faster. Like 1000 rpm would be great!
I will probably need to retain the indexable nature of the stepper for cutting some non-round features (think keyway). So I can't simply replace it with a DC motor and be done.
Given the very low torque and step-resolution needed, what came to mind is just mounting a big stepper here and direct-driving the whole thing, chuck, spindle, and foam. The foam's light but I probably want to use the Taig 3-jaw self-centering chuck and that does have mass that will never be perfectly on-center. I can slow way down the Acceleration in Mach3 to account for the chuck inertia.
In short I think I need some sort of pillow block capable of holding the stepper on one side and the chuck on the other. I looked at the pics of the Sherline tailstock but does that even have bearings inside, or is it just a point?
At this point I have only limited ability to make threads to mate with the rotary table. Hardware/software skill level and tooling limitation there. I do not have a lathe. I've got a tap and die set but that is probably larger than anything I have.
I also had some thoughts of using a portable drill chuck, the idea does have some merit.
Thoughts??
