Originally Posted by
nateman_doo
Got it to work. Problem is the motors are backwards, and the Y axis sounds crunchy, while the X moves well. No idea, both just as easy to move with the power off.
that crunchy sound is most likely missed steps...lower accel and/or velocity untill it goes away...then build in a little safety margin...doesnt really take "much" force to cut most of the energy is spent moving the table...if it will rapid without missing steps with the gibs tightened properly then good chance you will have no problem cutting...
http://www.g0704.blogspot.com/
