587,714 active members*
5,268 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Opening a Dwg and retaining text settings
Results 1 to 2 of 2
    Apr 2013
    70
    I have a customer supplied drawing that is in .dwg format. The part is a print die that the font and format must match the print. When I open the drawing in Bobcad v27 the text no longer matches the original drawing. Also the text settings in Bobcad will not re-create the exact settings that are in AutoCAD. Is there another way to get around this problem. Attached is the original drawing in dwg and dxf.
    Attached Files Attached Files
    35538
    Re: Opening a Dwg and retaining text settings
    Have the customer explode the text using the Explode Text express tool.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. HPR Nozzle Retaining Caps
    By Cmcclure in forum Hypertherm Plasma
    Last Post: 02-17-2016, 04:52 PM
  2. Replies: 8
    Last Post: 07-26-2013, 01:24 AM
  3. retaining cap
    By grogsroom in forum Hypertherm Plasma
    Last Post: 01-10-2010, 02:32 PM
  4. Retaining tabs
    By ssozonoff in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-05-2009, 10:43 AM
