587,933 active members*
3,788 visitors online*
Results 1 to 5 of 5
    Jun 2008
    91
    Ghosting effect while cutting - duff laser?
    Guys, pretty sure I know the answer to this, but can you take a look at the pictures below? Essentially, at anything above engraving power on my K40 clone I get a ghosting effect clearly visible on the first picture. in the second picture you can see the laser output marks, the left one is direct from the laser to the first mirror, and the second is what the 2nd mirror 'sees'
Name:	Laser output.jpg
    I am assuming that as the double spot thing is directly from the laser that it is a problem with the laser itself? If not obviously I'd like to know what can be done to correct it if possible. I can cut and engrave fine over the entire area of the laser bed, I spent a good amount of time aligning everything and fixing issues with the K40 clone itself. These include making two replacement brackets at the correct height, replacing the really sh***y screws, tightening up a load of stuff that was loose.... a pretty long list
    Any advice gratefully received
    Cheers
    Les
    Mar 2016
    94
    Re: Ghosting effect while cutting - duff laser?
    HI
    Yep had that one with a pretty new tube, so replaced the tube and everything was fine again
    Dave
    The photos are soo blury, I can't "clearly" see anything.
    Sent from my SM-G935F using Tapatalk
    Jun 2008
    91
    Quote Originally Posted by Dtcrafts View Post
    HI
    Dave
    I imagined it would be the case. I've gone for a Ten-High laser tube as a replacement, it comes with the wires attached so hopefully won't be a hassle to fit. If nothing else I will have a back up. I also went for an upgraded head and mirror assembly, hopefully that helps too
    Cheers
    Les
    Jun 2008
    91
    Changed the laser for the Ten-High one, immediately better! And lucky old me didn't even have to redo the alignment, it was right on.
    Cheapo laser = rubbish!
    Cheers
    Les
  1. Cutting effect of YAG machine
    By EXLASer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-09-2013, 10:35 AM
  2. Duff Milling Machine, Ever seen one?
    By voltsandbolts in forum Uncategorised MetalWorking Machines
    Last Post: 04-12-2010, 10:14 PM
  3. cursor ghosting problem
    By Derdle in forum Surfcam
    Last Post: 05-21-2008, 05:10 AM
  4. KeyCreator Ghosting Problem
    By TronCarter in forum Uncategorised CAD Discussion
    Last Post: 02-06-2008, 03:42 PM
  5. MasterCam and Ghosting !!!!!!
    By dmealer in forum Mastercam
    Last Post: 04-27-2005, 01:04 AM
