Bought this machine in Jan 2013. It's been sitting most of the time since then. It's got about 20 hours of use on it.
Recently doing a project in 2024-T3 using a 1/2" 4 flute cutter with about .010" depth of cut at about 3000 rpm. Taking a slow feed because a lot of time is already invested in this part on the manual lathe. Cuts fine for about 10 minutes then the motor slows to half speed. Then after turning it off and on it cuts fine for another 20 minutes.
The next day it goes 15 minutes again and then slows and totally stops although the table keeps moving. It gouges the part but luckily it wasn't at full depth.
Run the motor with no load and it does the same slowing to 1/2 the set speed even using the manual motor control on the cabinet face. Open the cabinet to look at the VFD and it doesn't act up again after that.
Suspecting the Chinese motor, it just doesn't sound right when it slows down. Guessing the only other thing it could be is the VFD but it doesn't look Chinese.
Sort of disappointed as this machine has seen very little use and it already has a major problem. Guess we'll see what Tormach says on Monday, maybe there's some known issues.
