587,920 active members*
3,428 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 18M controller Flash ROM software corrupt- Machine will not boot up
Results 1 to 6 of 6
    May 2014
    174
    Dear friends.
    We have determined that the files inside the Flash ROM are damaged or corrupted.
    My question is; since we have 3 machines with the same 18M control, and only one is having trouble, is it possible to use one of the good working machines to FORMAT and RELOAD these corrupted files (NC BASIC, SERVO; PMC, ect) with good working files into this suspected damaged card? Or buying a new card is our only way out of this situation? I will appreciate your inputs.
    Thanks !
    peloflex
    Apr 2009
    1380
    Re: 18M controller Flash ROM software corrupt- Machine will not boot up
    Please provide the part # of the main cpu. You could have one of several models.
    May 2014
    174
    Quote Originally Posted by memoryman View Post
    Part Number on that 18M is: A16B-3200-0210/02B
    thank you.
    FLex
    Apr 2009
    1380
    That is a 18-C control. You can copy the system software and the sram; make sure that you back everything up as much as possible.
    May 2014
    174
    Would you happen to have some sort of instructions set for the procedure that you are describing? Is that something that can be done from the Boot system menu screen? or do I need to rely on one of our good working machines to run that copying operation?
    Apr 2009
    1380
    We have a procedure to change/restore the main system files, and have done this successfully on the 16/18 iA systems.
    It may be better to talk over the phone: 289 389 6117.
  1. Help Needed replacing corrupt Centroid M-400 Linux Flash Card
    By RDOpp in forum Uncategorised MetalWorking Machines
    Last Post: 12-11-2013, 05:30 PM
  2. laser software disc is corrupt, please help
    By spacer777 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2013, 12:15 PM
  3. Replies: 0
    Last Post: 01-14-2013, 09:03 AM
  4. Need help with machine controller software
    By purecnc in forum DIY CNC Router Table Machines
    Last Post: 05-12-2011, 10:39 PM
  5. Corrupt Software
    By ericwaa in forum Milltronics
    Last Post: 10-08-2009, 10:30 PM
