Back up your post first.
Then, open your postprocessor file and search for ptlchg_com or ptlchg
Add your M00 before toolchange as shown here before the M06
Code:
ptlchg_com #Tool change common blocks
pcom_moveb
c_mmlt #Multiple tool subprogram call
#ptoolcomment
comment
pbld, n, "M00", e<----------------------add here
pbld, n, "(", "INSERT TOOL", *t, ")", e<--if you want to see tool #
pmisccheck
pcan
if plane < 0, plane = 0
#if stagetool >= zero, pbld, n, *t, "M6", ptoolcomm, e<------no M06
spaces=0
You can also use # to comment out a line. You can comment out any lines that refer to M06 and T if needed. Don't forget to backup first.......If you get stuck. "Post your post" and an example of your desired output, and I'll help you out.
Powered by:
