587,475 active members*
3,753 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Ultimax3 Disk Failed
Results 1 to 4 of 4
    May 2008
    10
    hi all,
    My machine Hurco BMC-30 ultimax3 (1994)
    error message: >> disk sub-system failed to initialize
    What must i do..
    Jan 2005
    49
    drive subsystem
    this could be caused by a bad floppy, bad hd, or drive controller on the cpu. try a new floppy first. standard 1.44 floppy. make sure no one has had their hands in the console or card rack moving cables. if your machine has the original executive disks in the back cabinet, you can boot the machine off of those disks. the machine will not run at that point, but you can then go to auxillary and select the upgrade master. the disks can then be loaded as an upgrade. if the machine will not boot off of the executive disks, then one of the above is bad.
    ron meyer
    Jun 2008
    1104
    Are you in Eskisehir?
    May 2008
    10
    Thank you, ron
    Im in istanbul, bloke
    epron .BIN file failed.. reloaded BIN file and it is resolved problem.
  1. Tried to buy a HF X2 yesterday. Failed!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 03-12-2008, 12:00 AM
  2. BMC20-Ultimax3
    By stevieboy in forum HURCO
    Last Post: 08-28-2007, 10:49 PM
  3. X axis transistor failed...AGAIN
    By Mr. Technical in forum Bridgeport / Hardinge Mills
    Last Post: 08-22-2007, 12:16 AM
  4. Boolean difference failed
    By chetosmachine in forum Rhino 3D
    Last Post: 06-12-2007, 11:24 PM
  5. Failed transformers?
    By Jetlag in forum CNC Machine Related Electronics
    Last Post: 09-09-2005, 08:50 PM
