I am not sure where to post this.
I have a shark cnc pro. I am cutting mostly all words, fonts, etc.
When cutting deeper fonts like Verdana Bold or Impact its great, the problem is when cutting smaller fonts.
For example when cutting a font like times new roman, some of the letters dont get cut all the way. This only happens on the far right or left of the board. The middle always cuts great no matter what font is used. I started to think the problem was the base plate was not level. I was correct, and I have since replaced the base plate and was assured this would work.
After some tests runs, same problem, small fonts or linework does not get cut at same depth on the left and right of the board, where the middle of the board gets cut fine. Also like before, bigger deeper fonts like verdana bold cut great and even all the way across.
I must be doing something wrong or do not have my table leveled right, can someone please assist and point me in the direction as I don't know what I have done wrong. Thanks in advance to anyone that can help!
Thank you!
