587,784 active members*
2,477 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Frame Design - Looking for feedback
Results 1 to 4 of 4
    Dec 2021
    21
    Any thoughts on this frame design I've come up with. It will be a bolt and epoxy build with adjustable feet. Length is 1.5 meters. Rail metal size will be 160x80 beams. Perhaps its a bit overbuilt, the y and z axis will carry a 2.2kw watercooled spindle.
    I haven't seen many builds which use a plate to fasten components together like how i'm joining the legs and rails but I imagine it should work, especially if I use metal powder epoxy to enable to surfaces to mate together fully.
    Jan 2008
    1543
    Re: CNC Frame Design - Looking for feedback
    No pictures showing for me
    Dec 2021
    21
    Hm strange i'll try and upload again
    Dec 2021
    21
    Reupload pictures attempt
    Dec 2003
    1237
    Still no images.
    Jan 2023
    436
    images don't carry through because you posted it through industry arena, the images from there don't carry over here at cnczone, some time ago two sites merged and they haven't fixed the this issue yet.
    https://en.industryarena.com/forum/c...k--463391.html
    Jul 2018
    6492
    Hi Thunza - bolting and epoxying connections is totally valid. Don't need to use metal filled epoxy. There are lots of epoxies for this purpose. If the connection is designed correctly and the bolts are sized and preloaded correctly, epoxy not needed. Friction is a very damp and stiff connection.... Peter
