587,409 active members*
3,265 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Arrow error 9036 HELP!
Page 1 of 2 12
Results 1 to 20 of 39
    Jan 2009
    9
    Hello,
    Can anyone help with this alarm error 9036 static RAM file system corrupted?
    It discription in the manual is (There is a proplem with the C: drive file system possibly due to a battery failure.
    These machines are 1994 cincinnati milacron arrow 500 that have a control techniqes interface
    The alarm comes up while booting up and can not go further. I have two of these machines that are idenical one is running.
    Thanks in advance for your help.
    CNC Programming, Inc.
    [email protected]
    253-514-1047
    Aug 2008
    386
    According to the operating manual, error 9036 static RAM file system corrupt,
    "There is a problem with the C: drive file system, possibly due to a battery faliure. Use test mode to check the file system. See section 5.3"
    Unfortunately, these are the worst laid out manuals I have ever seen, and although there are quite a few section 5.3s, none that I have found in ANY of the 4 manuals have anything to do with diagnosing this error. If you have not done it already, you should record the axis parameters for the machine. I will email you the info I have for recording/entering those parameters.
    Joe
    Jan 2009
    9
    Hi Joe,
    Thank you for your help. Looks like I need to be prepared to have a pc with Dos installed.
    I'll keep you updated on my progress.
    Matt
    Oct 2005
    11
    It's been a couple of years ago, but I had a memory error on my CT control. Maintenance Technologies had me download the files to my PC then copy them back onto the control which fixed the error.
    Give Maintenance Technologies a call and they will walk you through it. www.maint-tech.com
    Jun 2013
    1
    i need help, my HDD is brooked for the Cincinnati Milacron, any body has this software, thank you
    Sep 2013
    14
    Re: Cincinnati Arrow error 9036 HELP!
    Hi Joe
    I am Daniel and i need help in restoring my machine with the error 9036 static ram file system corrupt. How do I use the test mode to check the file system? My email is:
    [email protected] and my machine is a CINCINNATI ARROW 500 with CT control FNC-5-005.THANKS IN ADVANCE
    Daniel
    Sep 2013
    14
    Quote Originally Posted by Stickerman View Post
    I have the files but how can i download then onto the control? Can you help me please.My email is: [email protected]. Thanks in advance.
    The alarms i have are: 9036,9070, and 9044. can yuo give me the cable pinout and tell me the right software for the download of the files please.
    Best regards,
    Daniel.
    Jul 2005
    107
    I had the same problem years ago. Robert Varney help me. The MAIN.PLC file is for the next version of the machine software.
    Executive
    FNC Executive- standard version
    Executive part number C50000
    Executive Revision Rev 2.568
    System Program
    System Program 2.567
    PLC
    CM Arrow
    91202654
    P0.11
    Robert Varney wrote:
    The 9036 alarm is telling you that there is corrupted data in the Main.PLC file. It may be possible to go into test mode and file maintenance call up that file and look through it to find the corruption. It should give you a line number of where the corruption is.
    The corruption could be caused by bad batteries in the memory card. With the power on replace the 2 AA batteries.
    Robert Varney,
    Application Engineer
    MAG IAS
    Global Services
    1780 Worldwide Blvd.
    Hebron, Ky 41048
    U.S.
    tel: 859-534-4748
    fax: 859-534-4999
    mobile: 513-375-1059
    Jul 2005
    107
    Open the attached main.plc file in windows notepad and compare to what you have. Do not try to copy this file into your control you can only compare it and make manual edits if you need to. The picture of the screen you sent is normal.
    Robert Varney,
    MAG IAS
    Global Services
    Hebron, Ky 41048
    U.S.
    tel: 859-534-4748
    fax: 859-534-4999
    Jul 2005
    107
    On your pc put a copy of cnc_com in a directory\folder by itself. Start cnc_com in a dos window\dos prompt. In file maintenance go to copy file. In there you will see copy from and copy to.
    Copy from C;main.plc
    Copy to I:main.plc
    Copy in ASCII.
    The RS232a port is drive I and the RS232b port is the J drive.
    Robert Varney,
    MAG IAS
    Global Services
    Hebron, Ky 41048
    U.S.
    tel: 859-534-4748
    fax: 859-534-4999
    Jul 2005
    107
    On the machine once you call up the file to look at it you can change it when you exit out of the file there should be an option for exit and save.
    Robert Varney,
    MAG IAS
    Global Services
    Hebron, Ky 41048
    U.S.
    tel: 859-534-4748
    fax: 859-534-4999
    Sep 2013
    14
    Hi Chivo
    Thanks for your help. Next week i will try to have a look at the files and i will let you know .
    Thaks.
    Daniel
    Jul 2017
    3
    Daniel,
    Did these backups and procedure fix your machine? I'm experiencing the same errors. I have my machines original backups but I'm having trouble communicating with the machine. I purchased the machine with bad batteries and trying to start it up for the first time since owning it.
    Thanks,
    Tom
    Apr 2011
    112
    hi guys this is the backup of a arrow 500 with CT control anyone know how to load them up to machine?
    Attached Files Attached Files
    Aug 2015
    32
    Hi did you fix your problem aventtini
    Apr 2011
    112
    Quote Originally Posted by pfp View Post
    Make a cable , get the software from last post send it that msdos software And Upload parameters
    May 2021
    1
    Hello,
    Can anyone help me with arrow 500 boot ? I'm receiving the error 9036 and 9070, after that goes to the test mode screen and I can't load any files to the machine. Does anyone know how to pass the test mode ?
    I appreciate any help my email is [email protected]
    Dec 2022
    15
    Quote Originally Posted by aventtini888 View Post
    Same issue. How to load machine? Cable what is pin wiring order?
    Aug 2015
    32
    Hi you need computer with old version of windows up to XP
    Cable Configuration
    9 pin 25 pin
    1 8
    2 2
    3 3
    4 6
    5 7
    6 20
    7 5
    8 4
    9 1
    You also require the cnc_com.exe which should be on one of the posts in a zip file. Also patience is very important.
    Dec 2022
    15
    Thanks a lot! Need test.
Page 1 of 2 12
  1. Arrow 750 with CT control error message 9036
    By DEAN-O in forum Cincinnati CNC
    Last Post: 02-11-2019, 01:17 AM
  2. Replies: 0
    Last Post: 11-25-2013, 02:13 PM
  3. New Cincinnati Arrow owner with servo error
    By mvas82 in forum Cincinnati CNC
    Last Post: 06-19-2013, 10:13 PM
  4. Cincinnati milacron 750 arrow error msg
    By A1 roper in forum CNC Machining Centers
    Last Post: 02-11-2011, 02:24 PM
  5. Cincinnati Milacron Arrow 750 Error Message
    By Nikon Phil in forum CNC Machining Centers
    Last Post: 02-11-2011, 12:08 PM
