587,104 active members*
4,287 visitors online*
Thread: G71 Fanuc 0T
Results 1 to 3 of 3
    May 2006
    214
    G71 Fanuc 0T
    Gentleman -
    How can I adjust the depth of cut if my machine does not take
    the "D" word (I get an alarm if I use it)
    This is my code:
    G71 P--Q--U--W--D--F--S--. (but I can not program D )
    The machine is doing it on it's own but the cut is to deep, from 1" dia.
    to .625 dia. does it with one rough pass. I'll like to go a least .100 at the time since we are turning 12L14 steel.
    Any help will be appreciated.
    Jorge
    Aug 2007
    1
    G71-ot
    See if this helps. I have to machines with OT controls. MF-T4 & MF-T6
    T4 uses the one line G71 P Q U W D0750 F
    Do not used decimal point in D
    T6 uses the 2 Line G71 U.075 R.03
    G71 P Q U W F
    U = the depth of cut and must have decimal point.
    Hope this helps,
    Wgen
    May 2006
    214
    Thank you for your help -
    I definitely can not use the "D" word. But I found out how to do it.
    It requires two lines:
    G71 U--R-- (The U will be the one that adjust the depth of cut).
    G71P--Q--U--W--F--S--
    Cheers
    Jorge
  1. FANUC & GE FANUC Repairs
    By RRL in forum News Announcements
    Last Post: 04-17-2011, 05:50 PM
