587,848 active members*
3,106 visitors online*
Results 1 to 2 of 2
    Jun 2006
    44
    Advice on a Haas VF0
    I'm thinking of buying a Haas VF0 from 1995. I have two cnc Lathes a Mazak and a Gildemeister but it would be new for me to get a VMC. I'm buying it beacuse I have a job coming up that requires square blocks to be drilled and tapped and also to maybe pick up some other jobs. Is there anything in particular that I should look for ? Is rigid tapping standard on this machine ? Any advice would be appricated.
    Thanks.
    Apr 2007
    178
    rtap is not standard and it can be costly. make sure it has a spindle encoder. if it is a vector drive machine then you should have rtap. the machine probably has brush type motors if it is brushless it is better if you can pull back the way covers and check for rust listen the machine when it rapdis if the machine whines it probably needs thrust bearings. check the spindle oil regulator and make sure it is clean and that it is giving oil to the spindle chekc the spindle temp. call haas and get a service history they will give you parts sold for that machine serial # find out what type of material it was used for.
  1. New and in need of some advice... well alot of advice!
    By GoonShoes in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2007, 01:03 PM
  2. Haas 2 haas serial comunication?
    By CNCgr in forum Haas Mills
    Last Post: 12-22-2006, 07:07 PM
  3. Haas VF3 Y cable fault error - advice?
    By JHR1 in forum Haas Mills
    Last Post: 05-28-2006, 02:05 AM
  4. '90,'92 Haas
    By leggetmachine in forum Haas Mills
    Last Post: 03-11-2006, 06:56 AM
