587,161 active members*
3,088 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Lathe x vrs. z feed rates
Results 1 to 3 of 3
    Feb 2011
    353
    I hadn't thought much about this subject until reviewing some else's program
    normally i would use the same feed rates on the x axis as i used on the z axis
    the print calls for a 32 micro on the face of the part and this program uses .010ipr for the facing cut .0312 radius insert
    if i use .01 in a ipr to microinches this comes out to 134microinches
    if when programming the .010 ipr because this is diametrical would the feed rate be .005 compared to a z axis feed rate ?
    if this is the case the the microinches would drop to 33 microinches
    Feb 2021
    2
    Re: Lathe x vrs. z feed rates
    No the thing that is changing on the x axis is the SFPM. As you get closer to center you SFPM drops to zero. What you would want to do is keep constant SFPM if you lathe can do that sort of thing.
    Jun 2015
    4156
    hy i also looked into this a while ago, trying to figure out the time needed to cut a face with g96; i just run a few trials to figure out if feed is full or halved, etc
    things may change for y lathes
    as for roughness, once you do the math, in reality you could go faster, because, if you use the calculated feed, then real roughness will be way better than expected; thus you can obtain a desired roughness at a feed > estimation, because, in reality, some plastic deformation occurs during turning, that will smooth out the surface. If you have an inhouse rugozimeter, then adjust as you go / kindly
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
  1. Feed rates
    By nickelsey in forum Fadal
    Last Post: 07-01-2016, 12:19 PM
  2. cutter leaving feed lines at high feed rates-walter prototyp end mill
    By shimmwagen in forum DNC Problems and Solutions
    Last Post: 02-07-2014, 11:44 PM
  3. Replies: 0
    Last Post: 01-23-2014, 08:54 PM
  4. Feed rates
    By forrey in forum Novakon
    Last Post: 11-29-2013, 04:55 AM
  5. re lathe feed rates
    By woffler in forum Mach Lathe
    Last Post: 05-27-2012, 12:01 AM
